Auto transmission oil for 68/69 Valiant VE?
Gus
Post by Gus »
Hi Guys.....does anyone know what is the correct transmission oil for my VE 273 auto please?
[And where to get some?]
Thanks very much
Gus
Re: Auto transmission oil for 68/69 Valiant VE?
i think due to its V8 engine yours has a TF904 the Borgwarner 35 was used in 6 cylinder cars
in which case you need the same as most other chaps on here
Chrysler suggest ATF+4
don't have auto trans so this is based on a quick search
if its a manual 3 or 4 speed box then SAE30 engine or SAE 30 mixed use anti foaming suitable for in sump gearbox do not put 90 weight gear oil in.... you can put ATF in if you want
do not put anything in it with additives for rear axle gears i.e high pressure additives the additives eat brass synchro rings
"F" type mineral ATF will be fine.
Gus
Post by Gus »
Thanks very much guys.......I sprang a leak from one of the pipes at the bottom of the radiator....and had a job getting home!
Gus
Gus
Post by Gus »
Hi Chaps......
Having looked at umpteen different brands/ prices.......Comma ATF Aqf appears to be at a very good price......an awful lot less than products such as @Castrol F Type etc....
Many oils don't state whether they are mineral or not?
Any thoughts/ reccomended brands would be appreciated.
Thanks
Gus
This is what I put in mine
https://www.ebay.co.uk/itm/121638082586
Gus
Post by Gus »
Thanks...Gus
SJH
Post by SJH »
I used Dexron 111 in my TF904
