73 Charger Front subframe mounts/bushes
Has anyone got any good links for replacement front subframe bushes? Mine resemble swiss cheese & the car wallows in corners worse than any yank I’ve ever owned!
- ScottyDave
Re: 73 Charger Front subframe mounts/bushes
Here you go
https://www.rockauto.com/en/catalog/dod ... 79456,body
you can also get poly bushes for the torsion bar Xmbr as well,
https://www.rockauto.com/en/catalog/dod ... hing,10419
Thanks for the links Scotty,
Unfortunately I can’t get the first one to open properly. I’ve tried on my phone & pc. Is it the body mounts that I need?
https://www.rockauto.com/en/catalog/dod ... +mount,673
Yes you need those and the torsion bar crossmember bushes to sort out the front mounts. The back axle it also on horrible rubber insulators for added slop....
- ScottyDave
RAGNAR wrote: ↑Thu Jul 16, 20 4:02 pm Thanks for the links Scotty,
Yes that's the one's I'd replace the torsion bar Xmbr bushes as well.
Firmfeel do the option of a solid alloy mount.
As Blue says the rear leaf springs are encased in rubber as well, have a look here.
https://www.rockauto.com/en/catalog/dod ... ator,13637
When I did some work on a mates '73 years ago, we replaced all the front insulators with ally spacers and I modded the rear to get shot of the insulators on the axle.
- ScottyDave
That's the route I've gone down as I had to replace my rear springs anyway. I've got the poly bushes for K frame and torsion xmbr.
