Hello there , just a quickie.....
Which is the WIDEST axle possible to fit my 67 A body Barracuda ? Even if this means putting the perches on no problem, as long as I get leaf spring clearance , even if I have to adapt the half shafts to fit my wheels !!
AND this must have the 4.5" pcd wheel fitment. ..believe me if " it sticks out " it will be the look I need !!
Thanks Ian
They make wheels in a lot of different configurations - you can even get them made to order.
This is about where the mounting flange is positioned relative to the overall width of the wheel rims.
You need to do more research to understand what is possible and how to measure "Backspace".
For example, Torque Thrust wheels that are around 8.5" wide usually have 3.75" Back space - from the mounting flange to the inner element of the wheel rim.
Thanks for the reply Pete, I've got a pair of 15" x 1 0" steels and 2 95/50/15 cooper cobra tyres , the wheels have a 4" backspace to drums. See scrappy pics enclosed mate, cheers Ian
To TIB3300,THEY ARE STAMPED 15" X 1 0" mate, the trouble is I need the large 5 stud pattern axle , so would be easier to 're weld the spring perches and have a decent strong diff ...or re drill a 7.25 axle that fits my car...but may not be up to the job if I fit a decent powered motor ! I want a big block ideally ..so probably have answered my own reply kinda thing
Dave , i be seen Jim's Barracuda before ,think his wheels are too big for my Street/ cruiser lol
Instead of asking whats the widest axle, you need to measure what you have ... Although Mopar considers them production cars, the difference can be large. Not uncommon to have an 1” or more difference to each side.
Measure from the wheel mounting flange to the opposite side wheel mounting flange. If your on your own you can clamp a piece of wood to each flange & measure the gap
Add the axle width dimension to your wheel dimensions. Based on your 4” offset & 10” width, this should give you +12” to axle width.
You then need to consider/take into account your intended tyre profile & width.
Then try to get a dimension between the arches, again carefully clamped wood can be your friend. A lot easier with a mate round.
Once you know these sizes, it will help you to pinpoint what axle your after, you can also consider different offset wheels to arrive at your desired vision.
Axle swaps can have more consequences than just bolting in, such as the need for case narrowing, re mounting spring perches, propshaft yoke differences, Rear gear selections/options, etc, etc.
The chances of finding the exact axle width you want, with right gearing, will be slim.
That’s not even considering your desire for more power in the future, Traction. Woes, etc
As advised, changing wheel offsets maybe an easier ....
a ford explorer axle is 4.5" pcd, 59 7/8" wide overall, has 31 spline halfshafts, and a 3.73 geared lsd. oh, and disc brakes too. with your 10" wheels they should be nicely 'out' of the arches. and if it measures up to be 'too' wide cut the long side of the housing and fit a second 'short side' halfshaft to narrow it a smidge under 3". i'll be doing this soon to one for my valiant.
ps they're about as cheap as you'll get that suits what you want too.
Hey Mark and Neil, sorry for late reply to your posts......
I've heard about the explorer axle use off a mate not that long ago , but he didn't have the knowledge you supplied mate , I'm planning on wheel arch / fender flares on the rear and Mark I really want to keep these
steel wheels , I tried to get some big slot mags but to no avail , I saw a set that's on eBay at present off a charger but they are only 14" and I still need the 4" stud pattern for the front hubs.
think I may eventually go down this explorer axle route......that way I will have discs on the back and the LSD .
i may have a pair of 10x15 slot mags for sale soon, very deep dish with little backspacing. it depends whether i end up using the 8 1/2's with 295 tyres or the 10's with 15 1/2" mickey t's. i'll let you know either way if you're interested? won't be long as i started narrowing one of my explorer axle's today so i can have a fit up soon.
If you subscribe to MotorTrend on Demand, they did the Explorer axle in a duster (?) thing on a recent episode of Hot Rod Garage. Def worth a look.
If not, I think they make one months video free every month so possibly available
Gavin Chisholm - 414ci W2 Stroker SmallBlock Panther Pink '71 Challenger convertible - in bits Car progress can be viewed here
Thanks guys, I really wanted some big slot mags ,I put an add on here under parts wanted last year but could not get any
I think the biggest I got offered were 8 x 14s ,Neil I may be interested in them...but want to keep the Mad Max look with these black steel wheels .......saying that slot mags and some side pipes would suffice
I may now have to put an add for some 14" small bolt pattern slots. ...just to " hedge my bets !!??
Mr Norm, I've seen clips of that recently and now harnesses similar on you tube Cheers Ian
P.s. Neil pm me with a number " if you did want to sell them pair of slots "
