Are dodge 318 lifters flat???
Morning
Just a quicky,
Are 318la hydraulic flat tappet lifters completely flat? are should they have a slight taper to the bottom ?
Thanks
I would like to crack on today with this, if someone could let me know asap please
Just a quicky,
Thanks
Re: Are dodge 318 lifters flat???
All non-Roller Lifters have a convex Base.
- mopar_mark
As Pete said Convex, which aids the lifter to rotate
Thanks guys
That will explain why i am having no spinny then, in the box of goodies with the engine are some completely flat ones.
I thought the ones with the convex bottom were worn flat ones
Lifters need to be matched to each individual lobe of the cam if previously used.
If they are not in order then they are scrap.
If the bases are Flat or Concave they are scrap.
Check this out......Uncle Tony
Looks like new cam and lifters time then Pete
So what cam to go for?
If I going to have to buy a cam , it may as well be a choppy one
...........Thanks again, saves me lots of grief
