Howdy. Just managed to fulfill the dream.. 383ci 68 on my drive, running well and wants for little. Very fortunate & still sinking in!
I wondered if anyone could help me with a couple of simple questions - if I wanted to put the front parking lamps back to standard US, what bulbs should I buy? It's been "UK'd by drilling the light units and installing small old school sidelight bulbs with the main bulbs it seems being reddish indicators
I'd rather them constant" old school" flashing when I switch on a turn signal?
Also the car has been well set up on a traditional dizzy.. Is it fairly easy to wire in a Tic toc tach as it doesn't have one.
All advice to a long term lurker & very happy new member appreciated
D
Very first MOPAR - 68 Charger - bulbs
Re: Very first MOPAR - 68 Charger - bulbs
Welcome to the Club.
It's great when a dream comes true!!!
I am over the moon. Saved hard/traded everything etc etc
Mopar or no car though?
hello there , welcome aboard, be great to see some photos
Welcome, great choice of car, if you want it to look original you need orange stop and tail bulbs, or get the stanard clear ones ang some yellow / orange bulb paint, the more coats you put on the darker it gets, why not wire in a normal rev counter unless you already have a tic toc tach. photos would be good.
As Derek said the original bulb will be a twin filament, like a stop/tail bulb but amber
now these things have offset bayonet pins so in theory you shouldn’t be able to put anything else in there
hopefully if you have a look the original bulb may still be there and the previous incumbent will have only moved the parking light wire to the separate sidelight unit
if you’re lucky move that wire back and you should be back to stock
Hello and welcome to the club, and what a Mopar to start with
look forward to some photos of what you have.
Welcome.
Oh, and wot Del said - unless you already have the ralleye(sp?) dash with tic-toc-tac I'd just go with a third party. In fact I have got the posh dash and gave up with the tic-toc-tac. Nice and easy - 12V and coil feed - done.
- tach.jpg (68.7 KiB) Viewed 1332 times
You can keep the original single front side/turn bulb if you use a bulb with one white and one amber filament. LED of course...
There was a previous post regarding light mods which gave UK compliance -
viewtopic.php?f=6&t=59155&p=643223#p643223
Can't thank you enough guys very much appreciated. I will get some snaps of it up here this evening. Well chuffed with it. Now if only the ice and salt would GTF...
