mot exemption form
mot exemption form
Anyone know how this works? My MOT is due on 17 may. The attached form says fill in the form and take to post office when taxing vehicle. My tax is up after the MOT. Just not sure if i'll get pulled over for no MOT.
v112-declaration-of-exemption-from-mot.pdf
(134.67 KiB) Downloaded 136 times
Re: mot exemption form
What is the VRN of the Dodge?
You could check it out on some of the DVLA web sites.
https://www.gov.uk/check-mot-history
Hi pete, i've done that. Just thought i would exempt it this year as we have Gov manned testing centres and some can be a right Bannarama. Failed me on a headlight 2 yrs ago after having them aligned 10 mins before test. Had re tested at another site and they passed it. Just pee'd off with them, you can get someone sympathetic or the complete opposite. no give, just pass or fail, no advisories.
I assume NI is the same as the mainland.
Does your V5c say "Historic Vehicle"?
That is the Key to the MOT requirement.
Mick70RR
Post by Mick70RR »
The easiest way is to go online and tax it when the MOT runs out. It will say your vehicle is over 40 years old and may be MOT exempt, do you want to declare it as Historic? Click yes, that's it.
Spot on, Mick!!!
:thumbright: :thumbright: Cheers guys.
or just complete the form and post it, job done.
Yes Pete, Historic Vehicle.
Pete wrote: Fri Mar 05, 21 4:40 pm I assume NI is the same as the mainland.
Home free then!
just taxed her at local post office for another year. MOT excempt for the first time. :)
