water in footwell
elevensies
water in footwell
Post by elevensies »
having water run down into the footwell in the pickup.
thought id cured it, but no... seems not
took the screen valance off, removed as much old sh*t there was got airline down it...and still both sides wet on floor grrrr
any other ideas, or fixes
11's
MMA 117
support our paras
"Utrinque Paratus"
https://www.justgiving.com/paracharity
Re: water in footwell
wiper seals
Heater matrix ?
elevensies
heater matrix would be water from there, not from when its raining, so i can discount that, but thanks
wiper seal, the flow of water is down the edges of the wing panel onto the floor, you can see it, again, i thing wiper seals would drop the water in the centre of the floor, but worth a look, and take the frond panel off again tomorrow
thanks guys
MMA 117
support our paras
"Utrinque Paratus"
Maybe even sealant in the roof gutter cracked and dried, allowing water into the A post and working its way down inside until it comes out the bottom.
You need someone with a watering can and try pouring from different places whilst you are inside with a torch.
elevensies
MattH wrote: Fri Mar 12, 21 9:37 am Maybe even sealant in the roof gutter cracked and dried, allowing water into the A post and working its way down inside until it comes out the bottom.
thats my next move Matt, that and pre checking my spelling....fat fingers and no glasses on = #-o
MMA 117
support our paras
"Utrinque Paratus"
Preview before submit - always!!
