QA1 UCA fitment guidance
Hi team, got a set of QA1 UCAs to fit to my Barracuda. They come with advertised extra camber, castor angles and I’m wondering if anyone who’s fitted these has advice on what adjustment on the cam bolts I should have?
In the past I set mine up with the usual, have the front bolts allowing the UCA as far out as possible and the rear bolt the opposite. Always put me in the ball park, but with these arms having extra degrees built in, wondering on best approach.
Re: QA1 UCA fitment guidance
Same procedure as the stock arms, you will achieve more caster when it's set up.
Right on, cheers.
