Fire Sticks
Re: Fire Sticks
I’ve always carried one of these…https://www.ebay.co.uk/itm/265272079209
- Stu
Re: Fire Sticks
Re: Fire Sticks
And then if you're anal like me you can get this decal...
https://www.ebay.co.uk/itm/312079551441 ... %7Ciid%3A1
- Stu
Re: Fire Sticks
Like it.
Got two extinguishers, one for the wall in case and one for the car. Thinking about just mounting it in straight on the tunnel between the seats, but not sure about having them in the sun at shows.
Suppose I could go just under the front of the drivers seat.
Re: Fire Sticks
I've always mounted the extinguisher between the seats since my first car in the '70s. I like to be able to get to it fast if I need it, and I did need it once when my daily caught fire.
This started as a small fire I could have easily dealt with had someone not used the extinguisher and failed to replace it. I could only stand by and watch it burn to the ground by the time the fire brigade turned up.
- IMG_0559.JPG (204.53 KiB) Viewed 930 times
- IMG_0562.JPG (186.67 KiB) Viewed 930 times
- Stu
Re: Fire Sticks
Jay-zus!
Tunnel it is, then.
Tunnel it is, then.
Re: Fire Sticks
Blue can be quiet hard on company vehicles.
Good call on the Fire Extinguisher, though...
- Stu
Re: Fire Sticks
Yes, I reckon it’s worth it with my well documented luck.
I’ll keep the fire stick, but much happier with the extinguisher, maybe I’ll mount it under the bonnet somewhere just in case.
Re: Fire Sticks
I would want it readily accessible - you don't want to go popping the Hood with a fire on the go and not have an extinguisher in your hand.... and the fire might not be under the Hood!
- Stu
Re: Fire Sticks
No, I meant I’ll mount the extinguisher in the car and the fire stick I might chuck under the hood somewhere in case.
- Stu
Re: Fire Sticks
Well, in a moment of a few too many beers, I clearly ordered a couple of those. No recollection of doing it, but they have arrived in the post…Blue wrote: ↑Wed Jan 19, 22 9:12 am And then if you're anal like me you can get this decal...
Only problem now is, how to get the painted on modern instructions off the extinguishers…
Re: Fire Sticks
I just stuck it on over the writing on mine, it mostly covers it..
- Stu
Re: Fire Sticks
Definitely not going to cover most of mine, the stickers are tiny!
- Stu
Re: Fire Sticks
By the power of Amazon next day delivery, I may have a solution…
