Valiant washer Bottle motor
as standard they are cheap and horrible
they are unique to the Australian smoked white smooth nylon A body STYLE washer bottles
when the motor goes Phuttt, its probably because the seal between the pump housing and the electric motor has gone, your electric motor will have rusted up in a bath of screen wash.
you have a couple of choices
1) ignore it and give an MOT man some flannel about the bottle being empty
2) try and fix it, jewellers screwdriver at the ready
3) put in one from another bottle with potentially the same issue
4) buy a US A body bottle and motor combo. it fits, its kinda right, it has Chrysler and a huge pentastar embossed on it, but it is wrong and everyone will know. its also not cheap
5) buy a motor from a Valiant specialist, two i can think of sell them. its not cheap by the time its fully imported....
6) use this https://www.ebay.co.uk/itm/173432668958
£7.60
i'd rather pay £7.60 than $55
yes they are just as cheap and horrible as the original
they mount in the same way
they look the same
to the informed observer, provided you keep the wires to the inner wing side.... its standard
you will have to put spade connectors on your wires and work out which way to connect it up
Re: Valiant washer Bottle motor
Good choice Dave :thumbright:
looks is not everything, functionality is important too.
My Barracuda came with a foot pump which was leaking on the carpet, so the first job was to put a similar electric pump next to washer bottle and a switch inside.
pass MOT every time.
rfullarton
Post by rfullarton »
great answer dave
Dave, is this a standard fit for original mopar washer bottles?
Cheers Steve :thumbright:
its standard fit for the australian mopar A body bottle
basically a bottle with a 1/4 inch hole and a rubber grommet
end of pump sticks through and its all held in place with a metal clip that presses the motor in, againts the grommet
Dont think the US end of things was this simple OR if it was the end of the pump was at Right Angles
like this
https://dantesparts.com/i-30499063-mopa ... ry:1389460
you could however adapt a bottle with this motor
put a bulkhead/pipe fitting in the current hole in the bottom of the bottle connect it to this pump's inlet and connect its outlet to your squirters
would do the job. just need to make a small clip to bolt it to the inner wing
if you have a hand pump style swap wiper switch for one with a PUSH action, and wire power to bottle motor
then from bottle motor to extra connection on new switch. when you P-U-S-H, it earths the wire from motor and it runs.
if it runs backwards, swap the wires over or indeed swap the pipes
Cheers Dave, thanks for the info :thumbright:
