1967 Dodgy Coronet
Re: 1967 Dodgy Coronet
I bet you're glad you din't sell it now.
Thanks guys, been out again today. Really smooth at highway speeds, although the gears/converter seem a bit mismatched pulling from a stop. 318 convertor with a 360 motor may be inducing a little more stall than I’d like, but it’s not stopped me enjoying the car. Just won’t be racing it!
Matt, it was (happily) a misdiagnosis ref the suspected holed cylinder. My mate had recently had such a problem with a 318 block and initially I thought I may have had the same problem. There’s Avery shirt bolt that holds the power steering pump on some cars and any bolt even marginally longer than stock can punch a crack, rupture, hole in the cylinder liner.
Thankfully not the case with mine.
Safety wise, the car needs the disc brakes and anti roll bar for sure or it’ll be in a Cornish ditch if I’m not careful.
Now looking to find a Holley carb as I’m not a fan of the stock Edelbrock on the car.
This week I have been mostly fitting carpet. And just enjoying driving it.
- E6E1DF26-6609-4E13-B111-1419BE0894A1.jpeg (249.76 KiB) Viewed 4258 times
So she is nearly ready for the show season
looking forward to see her at the MOPAR NATS then
Well, I’ve got the weekend booked off, but whether I can afford a 600 mile round trip in the Coronet is definitely a maybe , might be up in the trusty old T4 camper
Hi Miles
Don't wish to hi jack your thread but did you used to own a 1987 Grand National , looking to get one and have been told that maybe you used to have one ............ need some advice ?
Yours
GUY
.......... KEEP UP THE GOOD WORK ON THE CAR , every little thing you are doing just makes it soo much better , looking good
Yours
GUY
Yours
GUY
Yours
GUY
- Stu
Glad to see you are back to enjoying it instead of kicking it. I know the feeling with frustration, but it’s all part of the game, I guess. Will be glad to able to go for a drive again, but stuck waiting for parts, so won’t be this weekend, frustratingly.
Where did you get the carpet set from?
Stu, I know that feeling for sure. Been driving the heck out of mine. Just spent an hour sorting a new silencer underneath using exhaust parts from the corner of the garage
Mate, sent you a PMguy whitwam wrote: ↑Thu May 12, 22 9:19 am Hi Miles
Yours
GUY
Yours
GUY
Been doing loads of stuff on mine, probably the most trying, but satisfying and eventually easy to do, was adding and subtracting leaves to the rear springs. I initially fitted a very heavy duty pair of Add a leaf/s to the spring set and reduced one stock leaf. That left the car way too high at the back an as Blue and Dunc observed, probably compromised my rear shox. Test diving proved that right and so I stripped it down and added a much lighter (but strong) leaf and now the suspension sits how I like it. The 3 pics should show it as too tall, as it is now and as it was before I changed the leaves around.
Next up is the front sway bar kit which this car desperately needs. Sort of unsafe at any (cornering) speed
- E7120670-F186-4AF8-BA0F-0679824E7119.jpeg (206 KiB) Viewed 4100 times
- 1BB6522C-868A-4315-8C4F-302F9342F26C.jpeg (173.65 KiB) Viewed 4100 times
- 96E0BB79-C5A0-4FA3-987E-677AA0582DAE.jpeg (232.06 KiB) Viewed 4100 times
Nice how the pic of the highest spring setting has the car upside down, as that’s where it was headed in the first fast corner!
I’m really lazy posting updates, but not lazy with the car. Stuff wot I done:
New fuel parts, sender, line, pump, carb
New front anti roll bar
New axle seals, green bearings likely next as they’re on the shelf
Now got both floor pans ready to be welded in
Messed around with wheels
And more
Driven it a lot
And more
Driven it a lot
- D879CEDF-4DA5-4725-85EB-2C6D86752A0C.jpeg (209.29 KiB) Viewed 3855 times
- 79E4016E-FED3-4B60-84C2-8B929C35E3F4.jpeg (212.56 KiB) Viewed 3855 times
- 2643BCCB-9DE9-4012-A7CD-940F049B9DC2.jpeg (249.42 KiB) Viewed 3855 times
- 371FA1C6-863D-4E18-8D12-906077FB1B66.jpeg (217.51 KiB) Viewed 3855 times
- 0D700376-167C-46F9-B22D-4EAC51CA1D96.jpeg (136.92 KiB) Viewed 3855 times
- 10470AFD-8145-4FB9-823E-16FE7602ED2C.jpeg (139.44 KiB) Viewed 3855 times
- C803A54D-0381-43D8-BB3F-5F13AB472F2A.jpeg (126.43 KiB) Viewed 3855 times
Well Done!
I like the "Driven it a lot" bit most!
- Stu
Good job you didn’t sell it, then.
Looking good.
Looking good.
About the selling bit Stu...meanwhile, new wheel bearings and next up is a new Pitman arm.
