'68 Charger RT
- westcoastdodge
Re: '68 Charger RT
cheers guys,means a lot
anyways pulled off both 1/4s and fix some of the mess under there,not to bad,replaced part of the inner roof structure above the left hand rear wheel house and replaced the shelf brackets.needed to replace the whole b post as some poor repair probably carried out years ago
- 20190210_113756.jpg (89.67 KiB) Viewed 2246 times
- 20190210_125507.jpg (107.36 KiB) Viewed 2246 times
- 20190210_125658.jpg (80.93 KiB) Viewed 2246 times
- 20190210_125711.jpg (88.65 KiB) Viewed 2246 times
- 20190210_162232.jpg (111.69 KiB) Viewed 2246 times
- 20190212_185840.jpg (110.95 KiB) Viewed 2246 times
- 20190212_193043.jpg (130.79 KiB) Viewed 2246 times
- 20190212_193153.jpg (115.97 KiB) Viewed 2246 times
- 20190212_193507.jpg (88.85 KiB) Viewed 2246 times
- 20190213_195607.jpg (90.44 KiB) Viewed 2246 times
- 20190216_022300.jpg (83.51 KiB) Viewed 2246 times
- 20190216_022234.jpg (105.96 KiB) Viewed 2246 times
- ScottyDave
- westcoastdodge
Re: '68 Charger RT
few small repairs to rear wheel tubs,rear rockers under the 1/4 skin were clean so prepped and epoxied,also prepped the rear 1/4 panels,some rear window frame repairs needed...
- 20190602_170539.jpg (84.35 KiB) Viewed 2243 times
- 20190602_184812.jpg (66.48 KiB) Viewed 2243 times
- 20190603_180407.jpg (90.83 KiB) Viewed 2243 times
- 20190622_200155.jpg (105.33 KiB) Viewed 2243 times
- 20190630_200721.jpg (123.33 KiB) Viewed 2243 times
- 20190630_200729.jpg (111.36 KiB) Viewed 2243 times
- 20190630_202032.jpg (80.51 KiB) Viewed 2243 times
- 20190630_205032.jpg (112.74 KiB) Viewed 2243 times
- 20190630_205057.jpg (104.86 KiB) Viewed 2243 times
- 20190630_215422.jpg (93.06 KiB) Viewed 2243 times
- 20190706_135933.jpg (110.9 KiB) Viewed 2243 times
- 20190630_215435.jpg (88.85 KiB) Viewed 2243 times
- 20190706_135923.jpg (100.22 KiB) Viewed 2243 times
- westcoastdodge
Re: '68 Charger RT
sure is Scotty,she was quite rusty when i dug into her,would not take to long to empty a bank account for sure...
Re: '68 Charger RT
Excellent work. Have been there myself and It’s pretty scary at this point but this looks to be going incredibly well. I never had that much rust under the lower window channels but my rear frame rails under the trunk floor were practically gone.
Really enjoying the photos and the thread, keep up the good work. There is some comfort in knowing I’m not the only one crazy enough to embark on a project of this scale
Re: '68 Charger RT
Seriously impressive work there, great stuff, keep the pics coming. This and the St Albans Charger show what can be done these days.
- westcoastdodge
Re: '68 Charger RT
getting ahead of myself a little here(again)roof was heavily pitted thin and quite a few pin holes(vinyl top car).lots of cutting and grinding later turns out the roof structure was not in too bad a shape with only one small repair needed
- 20181028_144120.jpg (85.41 KiB) Viewed 2209 times
- 20181028_200543.jpg (100.24 KiB) Viewed 2209 times
- 20181028_201058.jpg (93.53 KiB) Viewed 2209 times
- 20181028_201104.jpg (90.74 KiB) Viewed 2209 times
- 20181117_163011.jpg (113.59 KiB) Viewed 2209 times
- 20190105_154746.jpg (93.93 KiB) Viewed 2209 times
- 20190106_162500.jpg (81.42 KiB) Viewed 2209 times
Re: '68 Charger RT
Amazing wok, but I didn't know you could get all those internal panels now.
When I got into the hobby you could not even get quarter panels! It was NOS or cut-offs from crashed vehicles.
- westcoastdodge
Re: '68 Charger RT
hi Pete yep agreed,did one of these around 10 years ago and nothing available,luckily it needed only frame work and outer 1/4 skins which were nasty at that time.id heard before lockdown that AMD where looking for the main roof inner structures to replicate which would be great
- westcoastdodge
Re: '68 Charger RT
rear parcel shelf was a little corroded and did not have this piece so decided to carry out a couple of repairs,turned out great
- 20190301_194625.jpg (113.43 KiB) Viewed 2201 times
- 20190301_194347.jpg (81.79 KiB) Viewed 2201 times
- 20190301_213423.jpg (85.54 KiB) Viewed 2201 times
- 20190301_214316.jpg (98.71 KiB) Viewed 2201 times
- 20190302_132531.jpg (97.03 KiB) Viewed 2201 times
- 20190302_183731.jpg (102.96 KiB) Viewed 2201 times
- 20190302_191406.jpg (90.42 KiB) Viewed 2201 times
- westcoastdodge
Re: '68 Charger RT
cleaned and prepped then used epoxy on the rear then finally wrestled the 1/4s into position then roof install,looking like a car again at this point
- 20200104_183742.jpg (99.77 KiB) Viewed 2201 times
- 20200104_172151.jpg (89.36 KiB) Viewed 2201 times
- 20200104_183145.jpg (74.34 KiB) Viewed 2201 times
- 20200105_214450.jpg (106.22 KiB) Viewed 2201 times
- 20200105_214507.jpg (106.21 KiB) Viewed 2201 times
- 20200105_214610.jpg (103.4 KiB) Viewed 2201 times
- 20200105_214521.jpg (111.23 KiB) Viewed 2201 times
Re: '68 Charger RT
That is some great work you are doing
Re: '68 Charger RT
you are 1 very brave guy or a complete nutter actually u r a brave nutter
IF ITS ON WHEELS, LOWER IT!!
Re: '68 Charger RT
Wow !! I thought mine had some rust when I restored it but nothing approaching this . Your doing a Fantastic job
Re: '68 Charger RT
Absolutely outstanding work there! Having made and replaced panels etc for my old 66 Fury I fully appreciate the skill involved in what you are doing. The detailed pics are extremely good learning tools....keep up the great work, this will be a beautiful car when it's done
