pinch weld end caps
these go at the top of the trim by the rear side window on the B pillar in the door opening of a valiant charger
they are the trim cap at the end of the pinch welded plastic strip that covers the spot welded seam between inner metal panels and the door striker upright.
if you have a charger you probably knew something was missing but didn't know what.... well this is whats missing
15AUD each the postage will kill ya but where will you find another.... exchange rate aint too bad at the mo.
https://www.facebook.com/groups/5006914 ... 8219429898
email or message Rob or see posts in valiant charger owners or aussie cars uk Intsatwitface groups as above
Pinch weld end caps Aussie Charger and others
- 273839523_10159087932409425_8691616715005886349_n.jpg (66.05 KiB) Viewed 43986 times
- 276026789_5047544408622254_8744677944294328227_n.jpg (58.38 KiB) Viewed 43982 times
Re: Pinch weld end caps Aussie Charger and others
Once you have one you can have as many as you want 3D printed or you could always make them yourself out of wood, that's what I would be doing.
yes indeed thats what he's done
My son has a printer ive just never got the time to sit down and design anything..
i'd have to teach myself first...
