Talk to me about methods and madness, please!?
Heat crossover blocking
- Stu
Considering doing this whilst I have everything apart, if not for any better reason than to try and get rid of the starting issues I get in the heat, which I’m assuming is vapor lock / fuel percolation issues.
Re: Heat crossover blocking
Shim steel or aluminium, to block both transfer ports off on the heads - Blue will be along in. minute....
Yes a piece of thin shim steel stuck to the head to cover the heat crossovers with high temp RTV before you fit the gaskets will do it.
- Stu
Yes, if I’d thought about it that’s what you did on the Polara, isn’t it?
Best see if I can find a supplier of shim steel close, then.
Ta both.
Ta both.
- Stu
Out of interest, do you know what sort of gauge you use? Looking on eBay to get some and varies quite a bit. Ta.Blue wrote: Thu Mar 30, 23 4:34 pm Yes a piece of thin shim steel stuck to the head to cover the heat crossovers with high temp RTV before you fit the gaskets will do it.
About 8 thou. ought to do it.
- Stu
Magic, ta.
