MSD repairer in UK
MSD repairer in UK
Anyone know of an electronics guru that can fix MSD stuff this side of the pond? My adjustable timing control isn't playing ball. All connections ,tracks on the board look good etc. No spark when connected up . Checked instuctions and even had someone else look to see it was correct. White wires have been cut for magnetic pick up which is correct. Googled someone called Zane at Zanetec comes up over Bristol but they seemed to have been around 10 years ago.
Re: MSD repairer in UK
I see that the original post was a while ago so you may have found someone to sort this for you but you could try Adam at [url]https://downtoearthautoelectrics.co.uk/url]
They're out near Braintree in Essex.
if you don't learn from your mistakes then they are just mistakes !
Hey, thanks Mark. I'd disconnected it having kinda given up on it given I got it s/h in the states but will explore that company. Thank you.
