100amp alternator
- pete walton
100amp alternator
I have had this new 100amp alternator in the spare parts box for a while and decided to use it on the Savoloy ,,,i am concerned being a complete electrical tosser that it will fry the stock electrical system i have tried to retain ...question is will the starter relay which is stock survive and were else should i be looking for a problem ....the stock alternator makes 60 amp i believe .....thanks in advance
Re: 100amp alternator
All will be fine
More amps faster charging
More volts not good
100 volts charging 12v battery . BOOM!!!
More volts not good
Alternator should provide whatever Amperage that the car needs when running.
When it says 100 Amps then that means it can provide up to 100 amps, if the car needs that.
It should be okay to use, but you can put a quick blow fuse in the main cable from the alternator to starter relay (or wherever your charging cable goes to. The size of this fuse should be just over the max you think your car needs, say 40 or 50 or 60 Amps.
This way you protect your cabling if something goes wrong and alternator decides to put more amps in.
I hope this makes sense.
it will only output the current the car needs..BUT try not to let it charge a really flat battery.. in that scenario it will try its damndest to output something north of 50- 60 amps i.e closer to 100amps for a period of time until your battery wakes up, if the ammeter is still used that would certainly nacker it and the wires to and from it.
if the battery is good and you never run it flat... no problem, the current it accepts will be 2 or 3 amps most of the time
- pete walton
Thanks for the replies will put a fuse in advised
