Frame measurement tollerance?
So, I am doing a bit on mine and I wanted to measure things up a bit. As they are all new bits going on I don't want it crooked, as it has had one up the arse towards the O/S, at some time in its past. . It is a bit redneck the way I have had to do it, ie Level car front to back and side to side. I found it hard as it is still fitted up. Then I found the wife's vileda mop an excellent size for the datum holes
I have found it is square with the plumbob marks on floor and the frame length is the same. The only question I have for you guys is the right frame rail is about 3/16 or 5mm lower than the left. I think this is within tolerance for a Mopar, what is your advice?
- IMG-20240504-WA0005.jpg (145.12 KiB) Viewed 33148 times
- IMG-20240504-WA0004.jpg (109.42 KiB) Viewed 33148 times
- IMG-20240504-WA0003.jpg (120.33 KiB) Viewed 33148 times
- mopar_mark
Re: Frame measurement tollerance?
Sorry, I’m unable to help.
I felt sure someone else would of come along by now, forum is not as active as it used be, maybe try some alternate forums or FB for assistance
Firstly I don’t know what the tolerances are but I would be wanting to work to an 1/8” if possible. If you can correct it by jacking stuff around then Personally I’d do it.
Thanks Blue I am going to line it up better when the trunk floor is out before the new one goes in. I had some good input from the E body forums too most said it was fine as is. As they chucked them together on the assembly lineBlue wrote: Mon May 13, 24 9:20 am Firstly I don’t know what the tolerances are but I would be wanting to work to an 1/8” if possible. If you can correct it by jacking stuff around then Personally I’d do it.
