big block oil pump
rocket70
big block oil pump
Post by rocket70 »
I think the pressure relief spring is playing up in the oil pump, as my oil pressure sometimes drops off on idle but comes back up when i put some revs on the motor.
Do i need to drop the oil to remove the oil pump and check/clean the spring?
Re: big block oil pump
You don't even need to drop the oil pump...
rocket70
Post by rocket70 »
Thanks Pete.
Oil pump is held on with 4 bolts, pump will pull out & also rotate if you need the space.
When you put it back, you have to align with distributor hex drive. Hex drive is driven from cam which in turn drives the pump.
Pump is self explanatory & easy to clean. Spring retainer might be tight if uts not been out for a few years, but shouldn’t be a big deal
rocket70
Post by rocket70 »
Thanks Mark. I’ll give the spring a good clean first and go from there.
