On my Charger there is a hole above the ignition key , it is probaly on other B bodies too, now some of you may know this some may not, it's for a light to show you where the key goes in the dark, I've wanted one of these for a while but just couldn't warrant the price people are asking, anyway, I was going to make one and was speaking to Seyhan Hussein about it when he said "I have one you can have, I won't be using it" what a great guy he is, he wouldn't take anything for it, thank you buddy, I was going to ask him if he had a spare Hemi he wasn't using but thought I would be pushing my luck.
I've now fitted it and it's working on a switch, Seyhan has said he will look to see if he has the timer delay so that I can wire it in the way it should be or I'll order one from the USA.
Once again thank you to Seyhan Hussein.
Hole above ignition key
- IMG_6325.JPG (55.66 KiB) Viewed 7643 times
Re: Hole above ignition key
Nice touch Del.
If you’re not worried about originality behind the scenes… I’m sure you could get a 12v timer over here.
