Was this once a manual trans?
aussie pete
Post by aussie pete »
Hi, I just noticed this on my 1972 charger 770 ( only had it 15 years 🙄), it looks like where the clutch cyl would go. My other charger 770 doesn’t have these holes.
Both are 318 v8 / auto trans, the one in question has a vague history but nothing indicates that it was ever a manual.
Re: Was this once a manual trans?
aren't heater/ac pipes often there? that's what it looks like to me. maybe this one had ac originally and your other didn't?
aussie pete
The heater pipes are on the other side but I think that you may be right on the air con suggestion, now that you have said that , I think that one of the option codes was for air con :read2:
yeah mine has/had aircon and i have 2 snapped off pipes from the aircon radiator (can't think of the term at the mo) thing there
H51 Option as per the plate
a clutch rod hole is oval
you probably have a fuse in the top position and an orange wire floating about under the dash for the aircon control light as well
Pete,
Contacting the Valiant Infobase that I mentioned will give a full breakdown on the car. They are also very pleased to be able to log the existence of more of these cars.
https://www.valiantinfobase.com/
