Rear shock absorbers
- Matthew Saxon
Hi everyone, I’ve got a set of 6 leaf rear springs on the way from ESPO in the states, expensive but the existing springs were done. I’ve gone with a 1” lift over stock just to give a little more tyre clearance with 15” x 255s. The Monroe air shocks in the back at the moment are pretty harsh so I might look to change them at the same time. Does any on one have any recommendations for shocks available here (so fed up of paying shipping and taxes) that they’ve fitted, also with the extra lift I’m curious whether I need to be looking outside the usual sizes. I am thinking of the Spax G3287s a bit pricey and maybe overkill?
Re: Rear shock absorbers
i'm running KYB Gas-A-Just all round
had them on for years
no complaints
also got +1" springs at the back
no complaints
- ScottyDave
- Matthew Saxon
Thanks for that, I’ll take a look for KYB.
- Stu
Chris Goodale may well have them on the shelf.
Goodale American Speedshop in Wisbech.
- Matthew Saxon
Thanks, I ended up getting them from RockAuto. £156 incl shipping and taxes and here 24hrs later. I don’t know how they can do that.
That's a good service! Thinking of the logistics of that is frying my head. You order, someone must pack it, run it by courier straight to the airport, onto a plane that's leaving shortly, over the water, land, through customs, to another courier and out to your door in 24hrs
Mathew,
Did the ESPO springs arrive from back in May and have you fitted them?
'73 Plymouth Duster
'92 Dodge Ram B250 (For Sale)
- Matthew Saxon
Yes they arrived a long time ago, I fitted them I ordered +1" springs from Espo and they lifted the back end too much, so I ordered some front mounts with 3 holes to allow me to lower them a tad, I'm sure over time they will settle and then I may put the front eyes in the standard hole on the front mounts. At the moment the car is being registered for me as it just arrived in Australia where we moved earlier this year.
Thanks Mathew,
Good info
and congratulations on your move to Australia, ,exciting times for you.
ps. think you got those springs just in time as ESPO I think were limiting / stopping some of their production going forward.
Good info
'73 Plymouth Duster
For a cheap shock I think KYB are hard to beat. I fitted a set on my Barracuda about 9 years ago when it was just a street car. The rears are still on there now and I see no reason to change them at this point.
- IMG_3128.jpeg (119.8 KiB) Viewed 20810 times
There must be something wrong with your rear shocks.
That just looks plain dangerous
