Intermittent cutout
Intermittent cutout
Hoping not a big thing - just running past the brain trust.
First shakedown of new engine last night - all good; no obvious leaks etc.
One little thing though - I seem to have developed an intermittent cutout.
Driving along, car stops - for about a second - then starts again. But it feels like a total ignition loss - this is born out by the temp guage (which is electronic) - I noticed that when it does it the temp guage resets (powers off and on) - you can tell as it goes off , then shows 300, then goes back to normal.
This suggests to me its nothing to do with the ignition (coil, alternator, module etc) - but its more of a 'total loss' - like someone has turned the key off briefly. Battery is new and secure. Everything in the bay appears 'done up'. Never had it before - steering column been out a few times - so thinking maybe knocked something there ?
Just wondered if any obvious 'gotchas' for this symptom ?
Re: Intermittent cutout
My first thought would be the large wire from the alternator that’s passed through the bulkhead plug to the ammeter and the back through the bulkhead to the starter relay. If I remember correctly the main power feed for the car is spliced off that to the ignition switch. So, a loose connection somewhere on its route or corroded bulkhead connections are the most likely cause.
yeah
or the ignition switch/switch loom
do you have a big bunch of keys/keyring? the constant swinging can wear the contacts
Sorted - and will be source for a later update.
It turned out to be an intermittent short from the positive battery cable.
Which lead to a significantly bigger problem I am dealing with now. Update to follow some point in the future.
Thanks team -
