Hi,
Just wanted to share a torque strap I have made for my 440 Superbee.
Mcgill Motorsport M12 x 130mm turnbuckle kit
Classic mini tie bar poly bushes and washers
Brackets made from some odd offcuts lying about.
Owes me about £40 in parts and a few hours to make it. Pretty happy with how it's come out!
David
DIY Torque strap
- David Walker
DIY Torque strap
69 Superbee
Hampshire
Blackrats Speedshop
Hampshire
Blackrats Speedshop
Re: DIY Torque strap
could you make a sort of u shaped 'saddle' to bolt to the same 2 bolts and go over the 'rose' joint to put the bolt in double shear? the existing bracket is then less likely to twist and over time crack. i'm a belt and braces type of person, i blame my farm upbringing
- David Walker
That's not a bad shout. I've got to replace the stainless bolt anyway with a high tensile version so could have a look at beefing it up further. Or use some of the 6mm bar I made the base out of.
Amazing how well it works. Just got to find and sort the knocking noise out that sounds worryingly like angry big end noises
69 Superbee
Hampshire
Blackrats Speedshop
Hampshire
Blackrats Speedshop
