a bit of this and a bit of that
we have such a wide variety of stuff in and out that i thought i should have a 'cover all' thread for it, apart from my nash and ashley's zephyr of course.
so to kick things off we have another ford exploder rear axle in to be narrowed. we'll remove the easy 2 7/8" we've done a few times before by cutting the long side of the casing and fitting a 2nd 'short' shaft. also we'll be redrilling a set of slot mags to ford/mopar 5x4.5" pcd to suit both the above axle and a straight tube front axle. this lot along with a small block chevy engine/box will be jammed into a henry j gasser project a mate's building ready for next years racing at manston along with occasional street use. i'll get some pics as we go along but i currently have the lergy so i'm stuck indoors, lol.
Re: a bit of this and a bit of that
we're collecting the '360?' fe engine and box sunday so we can check if it's actually a 360 or a 390. my problem now is the fact that it's manual so i'm looking at 5 speed boxes to bolt behind it. it's a sickness this hobby/lifestyle of ours and there seems to be no cure #-o
we dropped the exploder axle off and collected the fe engine and box today. no time to check the 'true' size yet as other 'honey dos' took priority at home, lol.
last week we put a socket and bar on the 360 engine after removing the spark plugs. it seemed that in the year between it first being removed (and turning fine) from the truck and it arriving here it'd 'stuck'. so we gave it some 50/50 mix of petrol and diesel in the bores. today we tried the socket and bar again and it turns easily and smoothly no problem, result. next job is to build the run stand and run it so we can assess the vital's before it either gets used or sold on. also we checked the stroke and it is indeed 'exactly what it says on the tin' which is a 360. at least i'll stop looking for 5 speed manual boxes to bolt behind it to go in my nash now, lol.
i knew i shouldn't have said that last bit #-o . i just got an 'offer' from an ebay seller dropping the price on a borg warner t5 from £850 to £595. bloody typical! now i have to stop myself buying it :-k
phew, i've got over that now :D
i have bought 2 new 'tools', a bigger floor standing parts washer that holds solvent cleaner not the cr4p water based 'eco' stuff they push on us now. what good's that if you can't chuck old stale petrol in there when you have it. my small eco type didn't like it and the pump melted! the 2nd thing is a dial back timing light from accuspark, the first timing light i've ever owned and i'm 61 now! :roll:
i'm even thinking about an afr gauge for my nash to make tuning easier. :thumbright:
i picked up a box trailer today. now my van's gone if i have to collect engines/boxes or other big/heavy stuff i'd have to put it in my s-max which is awkward with an engine crane (ask me how i know #-o ). anyway for £60 i got a tidy trailer, quite heavy duty with brakes... and one wheel, lol. they look like mini wheels so i've checked ebay and both 6 and 8 ply trailer tyres are reasonable in 10" so that's an easy fix. also the rear lights are broken but i have a trailer light board already so again an easy fix.
we had to do a quick wheel job to get it off of ashley's truck yesterday. so it was out with the jigsaw and an off cut of mdf and before long we had a 'wheel' on the trailer making moving it easy. not the first time we'd made these wooden wheels and probably won't be the last, it's a quick and simple way to get a project mobile.
parts washer arrived today, it's bl00dy heavy!. i'll unpack it some time this week and decide where it's going. there's 25l of solvent cleaner on the way too so it gets a good start before stale petrol, old thinners etc gets poured in there too. ;)
we finally got round to finishing the wood burner and installing it, we only started it 2 winters ago so not too bad it proper stinks while it's burning the labels and paint from the compressor tank it's made from. the small bottom door is the 'air bleed' and access for removing ashes, it works well. the chimney has a good draw with no smoke in the garage so we're all ready for the colder weather.
neil
IMG_0001 (139).JPG (113.6 KiB) Viewed 120106 times
IMG_0002 (91).JPG (103.49 KiB) Viewed 120106 times
IMG_0003 (63).JPG (102.72 KiB) Viewed 120106 times
IMG_0004 (44).JPG (115.1 KiB) Viewed 120106 times
i've just bought a set of 390 fe conrods and pistons off of ebay. the guy has the 390 crankshaft too so i'll get that when i get the pistons/rods. ''why do i want these bits?'' you ask yourselves. well if you remember a short while ago i bought a 360 fe engine, they're basically a 390 block with a shorter stroke 352 crankshaft. so by swapping in these latest purchases i'll have a 390, result. :thumbright:
with at least 1 engine and box more than is 'needed' i spoke to ash about throwing together a cheap race car to use at manston now they've confirmed next year. i mean it'd be rude not to wouldn't it? :thumbright:
today the prw platinum series roller rockers arrived for the 318 build, thanks stu. :thumbright:
IMG_0001 - Copy (5).JPG (115.09 KiB) Viewed 117369 times
it occurred to me today that i shouldn't 390 the 360. it's likely the 360 will run fine as is so surely i'd be better off boring one of the 'spare' 352 blocks 50 over to match the stock 390 pistons so i'm starting with nice fresh round bores and new rings. that's give me 2 running fe's, 1 4r70w o/d auto box, 1 fmx auto box and the potential to bolt a (better than the truck) manual box to one too as the 360 came from a manual truck. 1 352 crank is bo11oxed so that would be the 1 to replace with the 390 crank leaving enough 352 parts to build another 352 as well as the 1 we're doing for ash's zephyr.
to sum up then between ash' and me we'd have 2 352's. 1 360 and 1 390. result :thumbright:
i went to have a look at a mate's new rod project today, a steel model A truck. it's an unfinished project and has nearly twice what he paid for it in parts alone. it has an un usually these days ford engine/box. it's a roller cam 302 with a tremec t5 manual box. he's got a rebuilt c4 auto' so had the t5 for sale. now remember the 360 fe big block i recently bought? that has the 4 speed manual truck box and i mentioned if a cheap 5 speed came up i'd mate it to the 360 for my nash gasser. you know where this is going don't you? as it happens he wants the narrowed exploder 8.8 axle locating properly to the 4 link, both were loosely tacked in place to make the project moveable and it's all skew wiff. it has the 'traditional' transverse leaf for springing, but he has a new pair of coilovers he wants on it so.... anyway i'll be having the rolling chassis brought to my garage so we can get the axle in place, the gearbox mount altered for the c4, rear brakes sorted and spacers for the engine mounts to lift it up an inch-ish as it's typically too low for safe ground clearance. oh, the middle of the gearbox crossmember will be made removeable too as (again) typically it's fixed meaning the engine and box need to come out to get the 'box out which is stupid imo. so for the labour on those jobs i get the new t5 5 speed 'box which i'm happy with and so is he which is good.
