489 case
Not sure if this helps but I am awaiting a set of 3.23's from Wil to go in my 72 Dart's 489 case instead of the 4:11's I currently have. I have a build sheet that specifies that's what I'm running but until we open it up we are not 100% sure. The car currently does about 60mph at 3000 revs which sounds about right for the ratio.
- Dave-R
Re: 489 case
Correct. It is the strongest unit but all the 8.75" axles are pretty strong.Yorkie wrote:I'm wanting a suregrip for the Coronet and looked at the numbers on the diff case thats in at the moment and it's a 489 which I understand is the stronger case.
A new ring and pinion is about $200.Is it better to buy a new posi unit and gears and have it built up rather than pot luck with a second hand unit.Or is the cost too much,looking at 4:10 gears.
A limited slip unit (clutch type sure grip) is about $400
The other bits needed to rebuild a diff such as bearings, shims etc would be about $100.
To rebuild the diff yourself following the clear instructions in the workshop manual would cost about a days work. The only hard bit is measuring and adding up.
I showed Trev Young how to do this a few months ago and he agreed he could have done it himself if he had known how.
The cheap option would be to buy or swap a complete used diff but the chances of finding a complete unit to your specification are remote.
It sounds like you and Autoholic could do some sort of deal though?
- Dave-R
How can you not be sure what gears are in the axle?
It is easy to find out if it has a sure grip or not. Just jack the back of the car up. If you turn one wheel the other will turn in the same direction.
If it has got the sure grip it is even easier to see what gears you have.
Just count how many turns of the propshaft you get for one turn of the wheel.
If it is just over 4 turns you know it has to be a 4.10:1, just under 3.91:1.
TYREMAN
